projet bassin sedge61
- esso1
Re: projet bassin sedge61
il faut l'installer a la main
c une vrai carte UNO ? tu peux mettre une photo ou un lien de la carte ?
ci-joint photo,carte commandée = arduino !
- esso1
mets a jour le pilote manuellement ou en automatique
dans le répertoire arduino, tu as normalement des Drivers.
\\programmes files \ Arduino\drivers
soit tu as un processeur Intel et tu lance DPinst-X86.exe
si tu as un AMD tu as dPinst-Amd64.exe
si il ne detect pas change de port USB ou supprime le pilote serial, et il redetectera a la prochaine connection sur USB ( debranche rebranche)
sinon tu as les drivers arduino.Inf pour une mise a jour a la main .
- esso1
pour la mise à jour à la main
du site arduino
du site arduino
4 | Install the board drivers
If you used the Installer, Windows - from XP up to 10 - will install drivers automatically as soon as you connect your board.
If you downloaded and expanded the Zip package or, for some reason, the board wasn't properly recognized, please follow the procedure below.
Click on the Start Menu, and open up the Control Panel.
While in the Control Panel, navigate to System and Security. Next, click on System. Once the System window is up, open the Device Manager.
Look under Ports (COM & LPT). You should see an open port named "Arduino UNO (COMxx)". If there is no COM & LPT section, look under "Other Devices" for "Unknown Device".
Right click on the "Arduino UNO (COmxx)" port and choose the "Update Driver Software" option.
Next, choose the "Browse my computer for Driver software" option.
Finally, navigate to and select the driver file named "arduino.inf", located in the "Drivers" folder of the Arduino Software download (not the "FTDI USB Drivers" sub-directory). If you are using an old version of the IDE (1.0.3 or older), choose the Uno driver file named "Arduino UNO.inf"
Windows will finish up the driver installation from there.
- nicolas65
c'est une copie d'arduino uno mais pas de la marque arduino
mon arduino(officiel) uno : une video pour installer les pilotes :
https://www.youtube.com/watch?v=S4guivepX6M
youtu.be/S4guivepX6M
une question, le programme arduino tu l'a installé avec un .exe ou tu a téléchargé la version sans installation en .zip ? car la vidéo c'est pour la version à installer
Pour ceux qui veulent réaliser un fat ou autre en plaque de pvc soudées ,il y a peut-être un moyen de faciliter la construction, d' améliorer la rigidité, faciliter la soudure et l'étanchéité en réalisant les bacs en pliant les cotés ; Ensuite , peut-être soudure dans les angles ou ajout d'un joint genre innotec adheseal ou similaire ,ce que j'ai fait pour réaliser la goulotte de collecte eau sale de mon fat .Pour le pliage,d'abord réaliser un evidement en forme de V avec une défonceuse à la place du pliage en laissant environ 1 mm de matière .Aprés il faut chauffer avec un décapeur thermique pour permettre le pliage sans casse,le plus dificille sur un pli de grande longueur où il faudrait s'y mettre à de 2.
Goulotte avec déflecteur inox et supprt UV.
Goulotte.Vous n’avez pas les permissions nécessaires pour voir les fichiers joints à ce message.
- esso1
j'ai regarder effectivement c'est un clone avec un chip different.
donc
regarde ici
http://www.microcontrols.org/arduino-un ... b-drivers/
tu as un drivers CH340
utilise le 1er liens pour l'install automatique, si ca marche pas , install a la main avec le second lien.
donc
regarde ici
ça y est , j'ai REUSSI à faire clignoter la led de la carte , aprés avoir de justesse échapé à la fusion des plombs ( les miens) .
Le problème: je n'avais pas dézippé le pilote aprés le chargement, eh oui,
. Quand on a jamais fait, ça ne s'invente pas .
Maintenant je vais rechercher comment faire marcher le FAT ,Aie Aie , sentez-vous venir les questions
LE plus dur c'est de décider de faire , alors
- nicolas65
faut y aller petit à petit, mon programme de mon fat au début faisait quelques lignes, c'était extrêmement basique, quelques lignes de programme, quelques câbles un petit moteur et un arduino sur le lit
en gros dans le loop():
si niveau bas ?
> sortie pompe rincage 1, sortie rotation tambour 1
delais 10sec
> sortie pompe rincage 0, sortie rotation tambour 0
maintenant à force de developer je suis à 500 lignes pour mon programme de mon FAT![angry [angry.gif]](./images/smilies/angry.gif)
si niveau bas ?
delais 10sec
Code : Tout sélectionner
void loop()
if(analogRead(0) >= 50) // si, niveau bas
digitalWrite(13,1); // pompe rincage
digitalWrite(12,1); // tambour
delay(10000); // delais 10sec
digitalWrite(13,0);
digitalWrite(12,0);
delay(2000); // delais 2sec
- esso1
ha... l'install des drivers, c'est top, une bonne étape de passer. ( ma carte était une chinoise, donc au début j'ai bien bataillé pour comprendre)
y a rien de sorcier, tu n'as plus qu'a écrire doucement le programme. comme Nicolas, tu commence petit, et tu ajoute de plus en plus..
